FATJACK
Good clutch and Viper hydraulics and it will shift like butta.
FATJACK said:Good clutch and Viper hydraulics and it will shift like butta.
moparman95 said:I wasn't in the market to buy a tank. You got a driveshaft yet?? We missed you at the track Saturday.
Mine has been a bitch to put in reverse, wants to pop out or grind some times. Am I low on fluid? just need to change it? or Clutch? hydrolics?... My weakest point is Manual Transmissions, I know don't know much on how ours is set up.
Which parts need fluid(i.e. clutch, hydrolics, gearbox, etc.) and which fluid to use.
Cause I think mine needs some attention. I'm having 3rd/4th gear issues as well as reverse.
So dude, you split your tranny for this? I've got 8 thousand miles, I shouldnt have to rebuild any gears yet:hmmmm2:My tranny did the same, popped out of reverse. I had to push the shifter and hold it for it to stay in gear. This works fine for a while but eventually it will fail completely and leave you with out reverse. My problem was the plastic pads on the shift fork was broken into pieces. When fixing this you will probably need a new reverse gear and slider, also replace all the plastic fork pads with bronze ones.
