Trouble code P0113
RMoore
Las Vegas
Just put in Roe SC and came up with this trouble code. Any know what it is? Where can I find all the codes listed?
Intake air temp sensor voltage too high.Do a search at the blue bar,top of page.
Before you try anything else...reboot the cpm...see if the code goes away.
Disconnect the negative terminal of the battery for 10 or 15 minutes...then reconnect it. If that does not clear the code, then you probably need to replace the sensor. When you replace it..do the .99 cent (five minute) mod referenced by Sean Roe that adds a 5.6 ohm resistor to the sensor wire.
