TRUCK CAME ALIVE.......
Yellow venom
Boosted Venom
Edmonton,Alberta,Canada
I finally got to the track last night,I met up with YellowFever#154 and ran a bunch of runs,truck ran great,Then on the way home,I couldn't believe how much the truck came alive,super super responsive,just feathering into the throttle and it was gone pulling very hard! Got to set of lights,got a red,took off 1/3 throttle and it broke loose like nothing!:burnout: :burnout: :burnout: The acceleration is how it should be now!! :burnout: Is this a normal thing? Anyone else have this happen? Now I get to go do the fun job :rock:, removing of rubber off the rocker panels! Any suggestions? Other then WD40??
A good coat of wax before you go to the track helps with the wash up afterwards.
On my buds 70 Pro Street Nova SS we spray on the WD-40 real light BEFORE we hit the track. After racing is finished we wipe it down with some quick detailer spray and it all comes right off:)
The e.c.u. adapts to new conditions and can make the truck feel much stronger.
Reset the e.c.u. before you go to the track.
HEY Ron where were you? Are you coming for the 9th then?? Resting the e.c.u before running?Will that make it run stronger? Right now,its running the best it ever has,So if I reset before running,it will run even better then now??:burnout: :burnout: :burnout:
I pm'd ya...
