Begood
I would guess that the TPS might be part of the problem.
TPS is throttle position sensor.
Bill.
Bill.
Begood said:I would guess that the TPS might be part of the problem.
Bill.
FlyingLow said:I thought about that but I don't know how to check or exactly where it is located.
It is on the passenger side of the throttle body. I don't know how to check it out though.FlyingLow said:I thought about that but I don't know how to check or exactly where it is located.
Bone said:Check some of the obvious first (not talking down to you).
Are any of the sensor wires burnt or melted due to the new install?
I thought he was talking about the fuel pump. lolBegood said:It is on the passenger side of the throttle body. I don't know how to check it out though.
Bill.
Bone said:You can hook up a scanner to see if it is reading correctly, incorrectly, or flat out not giving a signal. Most shops will have a scanner to read the O2 sensor.
I ment the TPS. The fuel pump is in the gas tank.Bone said:I thought he was talking about the fuel pump. lol
Begood said:I ment the TPS. The fuel pump is in the gas tank.
Bill.
FlyingLow said:Is that scanner different then the SCT? It only shows me the code.
Muzzy said:The scan tool will tell you pretty much the same as what the code says. Sure you will see the low voltage reading on the tool. What it won't tell you is why the voltage is low. That is where you have to start checking the wiring and the harness for shorts or an open.
-Muzzy
