McLuvin
OK guys. Got the motor back from i replaced the senso. the builder. Looks great dropped it in. Won't idle and it misses. Hard to start sounds like timing. Low power on the street. Though I didn't try very hard due to circumstances. I did gas it a little to see if it would clear up in the mid range. It does. Though not completely. I backed the cam pos sensor out about an 1/8 in and then it would idle and crank smoothly rather than that har crank it had before. I replaced the sensor. No help. The timing chain is now a cloyes setup. Has adj cam timing. Also, the unit is made for Gen 2 so the timing marks must be ignored. The builder has used these before with no problem. He said he matches up the stock gear and the timing should be set to stock. Before I loose my head. Can anyone give me any suggestions. The battery has been out of the truck for well over a year. I reinstalled the tune with the sct to make sure nothing was lost. Has 2 bar map and larger injectors. Really sounds like a timing issue to me. What else could cause a timing issue? I haven't looked at the crank post sensor at all. I do know that when I pull the cam sensor back a bit I get a P0340 cam pos sensore circuit.
any ideas would be great. Thanks in advance...
