bigredv10
If you want your best time I would advise taking out the back seats, empty your glove box,consloe EVERYTHING that you dont need at the track... if you loose 500 lbs that should be another half second with good weather
Troy's QC SRT said:Dont require smog where i am so there will be no cats...I plan on getting catless mids at least if i can't afford the B&B headers...Dont know what you mean by the whole flow bend process...Are'nt our exhaust already 3"?
mmmmtorque said:Nope, not 3"...dont quote me on this but from what I remember its 2 7/8" OD and 2 5/8" ID +- 1/16"
If you have any exhaust work done you want a well thought out mandrel bend with performance in mind.
Not only is the stock not 3" it has several unnecessary bends (at least in the RC it does) that restricts flow.
Actually on your Magnaflow the inlets (and internal crossover) are not true 3" ID.
I cut the inlets off of my Magnaflow and had true 3" to the inlet. I believe it made a subtle improvement on the sound of my truck as well.
I take it if you ever go the Header route your are going Bassani? Mine performed pretty well and picked up 15rwhp, improved exhaust note and saved at least 10lbs.
Another cheap 'bolt on' is battery relocation....
505'sFastestViper. said:cats i see you got the rear ones out now take out the other ones for sure that will help!!!!!!
