Here are the finished pics of the bed tubbing. I will solve our traction issues now.
tinygiants said:Here are the finished pics of the bed tubbing. I will solve our traction issues now.
I am talking to Jack about it. My local fab guy wants to use Chris Alston as the supplier. Jack thinks the links are to small in that setup. So we will see.Stinker said:Very nice Tiny:rock: you still going fo link?
I am still up in the air on mine, but its getting cold , I need to make up my mind
I plan on running this tire. http://mickeythompsontires.com/street.php?item=SportsmanSRnycstev said:What setup can we run with this that we couldn't have run before?:dontknow:
The MT rims are the wrong bolt pattern. I am still searching for rims. Right now it all depends on the back spacing, then I can get serious.Justanotherdodge said:I thought those rims where the wrong bolt pattern? are you going with a conversion or did you talk them into making a special pattern on the rims for you?:dontknow:
tinygiants said:I plan on running this tire. http://mickeythompsontires.com/street.php?item=SportsmanSR
It is 33 X 20 X 20. The tubbing is just the first step of the install. I still need to remove the rear springs. My plan is to do this by changing over to a 4 link. This will address the traction issue in 2 ways: Tires, and Axle Control. While I am in there I will upgrade the axle with either a FAB 9 or the Stinker Rear End. It will depend on weather I need to narrow it or not.
No. It will give more traction on the street than anything else. And it will let me run the big (15 inche wide) slicks like Jack should I ever need them :rock:nycstev said:Looks like a serious setup. So this will give more traction then the Stinker rear
with slicks?
Stinker said:Tiny , talked with DTS yesterday bo, Mike agreed it would be best for you to talk with him on the measurements, and actually to talk with him before you start measuring, says there are a few things extra he may want.
Just tell him I told ya to call , (he knows me waaayyyy too well,LOLOL)
here is his number Mike 1-877-874-7327
WOLFRAM said:Is this the same guy you were going to talk to about my project?
