Uh Oh!!!!! Please read
1fast10
Savannah, Ga.
So I take her out for a cruise yesterday... and in the way home everytime i accelerated and then let of the gas she started hopping sort of like when you let out too fast on the clutch of a manual. To make matters worse dealership isn't open till tomorrow morning 7:30... Its really causing me to worry. Just need some info or stories from trucks that have done this before. Thanks
OH YEA!!!!!!!!!! I also forgot to mention everytime i get on her theres like a crakling noise... and sometimes I can hear some water or something slushing around in the firewall area or under the dash
Fuel filter??????:dontknow: :dontknow:
thewelshm
Hmmmmmm...bad U-joint? Do the QC trucks have carrier bearings on the driveshaft? I had a truck years ago that had a bad U-joint and carrier bearings and it did the same thing...:dontknow:
i just went out and shook the drive shaft by the joint and it did move about a 1/3 inch either way... is that normal.....
Down the list of items to troubleshoot and may not be the case but your flywheel/flexplate may be failing. Mine did, and at the end had symptoms similar to your description. Failure was at 41,000 miles. There are 2 other local quad cabs that have had multiple flywheel failures.
I hope you find it soon and it's something simple.
oldguy
Don't know about the hopping, but I know the exact sound you are talking about with the water sloshing around. My GMC does the exact same thing, has for years. Never bothered to worry about it, it's just a beater truck. Think it has something to do with the heater core. Let me know what you find out.
yeah thats air in the cooling system. just needs bled. dont know about the hopping. havent heard of that before.
It's those muffler bearings again. Got to rotate them every 30K.
RUNOUT SPECIFICATIONS
Front of Shaft 0.030 in. (0.76 mm)
Center of Shaft 0.015 in. (0.38 mm)
Rear of Shaft 0.030 in. (0.76 mm)
NOTE:
Measure front/rear runout approximately 3 inches
(76 mm) from the weld seam at each end of the
shaft tube for tube lengths over 30 inches. For
tube lengths under 30 inches, the maximum
allowed runout is 0.020 in. (0.50 mm) for the
linemup said:
And don't forget to check the headlight fluid!:D
Don't you check the blinker fluid at the same time:dontknow: ;) :marchmellow:
For sure!!!
Realy though I hope you get it figured out, and it's nothing major!!!
Hey Pete,
Call me when you hear from the dealer!!!:burnout:
Well guys figured it all out ant things are looking up... except that crackling noise
what was it:dontknow: :dontknow: :dontknow:
