faslane505
Bone said:Where are you located?
im in north houston...i took it to austin though
SRT10VENOMOUS said:are they going to fix it for you at no cost??
fasstdak said:Yes, a torque wrench was used on all bolts that require it and to factory spec. Why the trans mount and crossmember bolts were left loose is something I don't understand. They were checked by myself and the other lead tech that helped reinstall the transmission. You had also mentioned loose/missing vacuum lines - all lines were verified as connected. The breather hose was missing from the truck as you had a breather filter on the cover and duct tape on the intake tube where the fitting should be.
The only way to find out what happened is to inspect for cause of failure. When you talked to me on Saturday, you let me hear the noise and described it as a squeaking/metal tapping noise. It's hard to say what happened by listening to it over the phone. As I also stated to you, I will talk to the manager on Monday AM (when he's in) and verify that this is covered under warranty (which is should be).
I personally am concerned as to why this happened when everything was double and triple checked within the engine.
fasstdak said:I personally am concerned as to why this happened when everything was double and triple checked within the engine.
faslane505 said:first of all the duct tape was to cover hole in my intake from when i was sprayin the truck before i blew the first engine...you dont even know what part ive been talking about...its a 3 inch neck that is on the bottom of the intake tube...its been capped for 9 months and the new engine has been getting unfiltered air through the IAC...
I agree with you,I take my hat off to fasstdak for coming here.I think i would let him find the problem,And give it another shot.Just my .02iraqivet01 said:Wow, this is like watching tennis. :bebored:
I respect fasstdak for coming on line. :rock: I thinking he just as concerned about the whole situation as faslane505.![]()
I feel comfortable to say they will make sure they will make it right, or will find out what other issues might have been hidden inside that engine.
You seem like a stand up guy fasstdak,I already know Robert is.I am sure you can work it out.It's starting to get better already.:rock:fasstdak said:It's happened to me personally as well - had a "reputable" engine builder do some upgrades to my old V6 (yeah yeah) and made it to Baytown for the Houston Mopar Races. Wound up towing it home after breaking 1/2 of the rings in the engine (wrong ring clearances were used with the pistons). I know what Josh is going through and I definitely know the frustration.
Once we know what happened i'll let ya know. I need to talk to my manager and Robert tomorrow AM and find out what route we need to take to get the truck back for repairs.
iraqivet01 said:I respect fasstdak for coming on line. :rock: I thinking he just as concerned about the whole situation as faslane505.![]()
