furgy667
- Joined
- Sep 16, 2008
- Messages
- 187
- Reaction score
- 0
I have been having problems getting the truck into reverse and sometimes first after the the truck has warmed up. Like setting at a read light . Also 5 and 6 gear take a good amount of force to engage ,again only after the truck is up to operating temp. There is no grinding or popping out of gear . It just takes added force to get it to take gear . Once in fist I have no problems at all with shifting. Wot shifts are great! Just click squeal click squeal click squeal:rock:
I was looking under the truck today and as I suspected It appears that I have a centforce clutch on the truck. Only making a guess here because I can see the red through the bell housing area around the hydraulic lines. I am assuming that the Stocker would not be red. I really don't think I have the upgraded Hydraulics
Would this be causing my problems?
Its not a huge deal atm but yesterday I pulled to far out in the road and had problems getting her into reverse. If i down shift into first before I make it to the red light first is not a problem , but if its a long light and I shift to N and let the clutch out (peddle still has plenty of pressure)I have to jam it into 2 then it goes into first pretty easy.
Thanks for the help
Brandon
Thanks for the help
Brandon
