Viper Master/Slave
BigRed460
Texas
I have a quick question about some of the ones that I have seen installed. The clutch pedal is way higher than the brake, I am 6'7" and haveing the pedel any closer would suck that much more. Is there an adjustment or space you can make, or does someone have a picture of one they made? I wont be installing it so i would like to have all the parts ready before hand...
i just purchased a roe clutch kit that includes spacer's for the clutch pedal, but pics showing this in an install would greatly help !!! anyone with pics ??:dontknow:
correct, there should be a 1/2" shim between the firewall and the master cylinder. Mine was just a taaaadddd too high, so I placed another washer on top of the shim to space it away from the firewall just a little more.
-Red
-Red
You're kidding. It's that simple to adjust? No ill effects with pedal throw???
-Red
do you have any pics of this ??
thanks.
boomer kit says it comes with one, justins doesn't say ne thing, whats is roes kit? the same as those two? cost?
http://www.roeracing.com/ProductCart/pc/viewcategories.asp?idCategory=79&pageStyle=P
Sharpi
I made 3/4" spacers for mine and they worked perfectly for me.I am talking about the spacers for the master cylinder where it mounts to the fire wall.My X-Metal kit came with shims that install in the trans itself for correct pedal engagement.
you need shims on the slave to get engagement right & shims for the master to get the pedal height right ??
the roe kit comes with 2 shims, is that one for each issue ??
thanks.
thanks.
Correct...but roe provides 1/8" shim behind the slave...should be a 1/4" and a 1/2 behind the master for pedal height (I also added 1 washed to it).
-Red
mmmmtorque, is your height and has installed the viper slave/master on his truck. Maybe he'll chime in on what spacers he used. Oh Charles.....
You rang ??? :D
My kit came with the 2 shims for the slave but had to shim the master via a trip to Ace Hardware. Used 3 or 4 stainless washers to shim out the master to adjust the pedal height. My clutch pedal is about 3/8 inch higher than the brake but didnt want to shim it anymore since I was running out of threads on the master bolts. You can replace the mounting bolts with longer ones and shim it down to the stock location if you want.
mmmmtorque said:
You rang ??? :D
your's was a roe kit ?
