water inside
ukraine
Hello people.
Recently after rain I noticed that I have some water in the rear bed where the SUBwoofer sits. Anybody has this problem? any idea where it can come from? and how to fix it?
In the bed or in the actual cab? You have no sig. so to figure out if your bed has a cover or not makes it hard to figure out what your talking about. I would assume if its in the cab its probably coming from the sliding rear window not shut or a bad seal. The vents are behind the carpet toward the rear of the cab. If you look outside the cab between the bed and cab you will see where they are physically located. Need more info on your truck to help though.
The water is in the SMALL plastic bed right behind the seats. the one where SUbwoofer stands in! I am talking about small one right behind the seats! I have 2005 RC!
congrats on RC :rock: .. year is less good....:eek: :p :D :D :D
i bet your rear window is leaking. check that. have some one spray it with pressure and you inside and you may see it leak.
gl
gl
why not her inside and him pressure spraying ? :confused: :dontknow:
PS Ukraine , don't forget pics and white T-shirt :rock: :rock: :rock: :rock: :rock:
i've got the same problem. whenever it rains hard, i get quite a bit of water inside. haven't figured out exactly where its coming from yet, but it looks like its from the area circled in my pic below.
TheMoparConnection said:
i see it all the time---reseal your third brake light housing
awesome, thanks for the tip dude!
TheMoparConnection - sure enough, that fixed it. :) i have an aftermarket 3rd brake light and one of the screws had backed out a little bit - just enough to allow some water in when it rains hard.
