Water on the belts= NO STEERING?
Yep, it's normal for these trucks... The new belt will help, but won't completely eliminate the problem. Especially in FL downpours. :eek: When it was wet, I knew it would squeal... so I just took an extra 30 seconds after start-up to let the belt dry itself. Maybe give the throttle a few short blips after that before you put it in gear and start moving. :eek:
Mine still does it even after a new belt. Have not tried the Gatorback belt, should have I guess.
You ought to drive about a mile and make 4 90* turns from a stop with no belt....:argh: .....I thought my steering wheel was going to break,,it was cracking and popping from the strain..or maybe that was me.:eek: .LOL....I had to about climb up on the steering wheel to turn it..
Sharpimage said:
Bringing this back from the dead because it's been raining here in Rochester
quite a bit and I can't stand the sound of it, as well as having to double
hand that steering wheel when it does happen.. So the conclusion is to
get a Goodyear Gatorback belt? What's the Part number?:D
Thanks,
Andrew
Gator back # is 4070685....I have it but still haven't put it on...:D
I haven't had to drive mine in the rain yet:D If I ever have to I hope I don't loose power steering:argh:
While it's moving your cool, it's when you stop and turn it sucks!!
hahah thanks for the number boss i'll be ordering one here shortly.. ;)
