what clutch
stick
pensacola
what clutch are you guys putting in after our stock clutch goes out?
so as yall have seen , i have been doing my fare share of racing. on my last 3 races i have smelled my clutch, not bad but i do smell it. Does this mean i will have to replace it soon or do you think i have still got a few miles to go? The clutch peddle still feels the same as it did when i got the truck, it now has 10,000 miles on it.
Probably dont need a clutch today but would guess it doesnt have much life left. As soon as its starts slipping at WOT you should place your order :D
Most folks are going with the Centerforce clutch, Fidenza aluminum flywheel, Viper Master/Slave upgrade kit.
Its good for 750hp and the master/slave is a must kit for most RC owners anyway ;)
Its around $1500 from X-Metal or Roe Racing.
Most go with the centerforce assembly for the clutch
You can also upgrade the slave and master cylinder units fromthose from a viper.
but if ya do this, the slave and master cylinder needs shimming.
Got the same setup. Huge huge difference from the stocker. A couple of hard lauches with any slippage of the clutch will burn out the stocker real fast!! Mine was toast about 3k miles.
patrick
i just talked to the guy who will be putting it in, and he wants me to go with a "spec" clutch. have yall heard of these people. i went on there site but seen nothing for the ram srt 10 only the viper? Is it the same clutch that goes in the viper?
