What is the trick to getting the rear rotors off?
Discussion in 'General Discussion' started by 2quik6, Nov 6, 2021.
Car Parts
  1. 2quik6
    2quik6 Full Access Member
    62
    36
    Jul 19, 2017
    The E-Brake is off, I have tried WD-40 all over, I have heated them up with a torch, I just can't seem to get them to budge. I have banged all over them with a 5lb hammer.
    At this point I am putting the new pads on and calling it a day with it, moving on to the other side.
  2. 2quik6
    62
    36
    Jul 19, 2017
    Other side is the same way, so I am just going to put the $400 rotors on the shelf for now as I need my truck today, and put it back together with the new pads. Will pay a buddy to do it some other time I guess....very disappointing, I do not see anything holding them on at this point.
  3. oldcolt
    2,752
    119
    Jul 14, 2008
    Calgary, AB
    From my 06 shop manual:
    REAR - SRT10
    1. Raise and support the vehicle.
    2. Remove the tire and wheel assembly.
    3. Compress the disc brake caliper using tool
    #C4212F.
    4. Remove the caliper pin bolts (3).
    5. Remove the banjo bolt (6) and discard the copper
    washer.
    CAUTION: Never allow the disc brake caliper to
    hang from the brake hose. Damage to the brake
    hose with result. Provide a suitable support to
    hang the caliper securely.
    6. Remove the rear disc brake caliper.
    There should be nothing special. it sounds like your rotors are seized to the mounting point on the hub.
    AMS3 likes this.
  4. oldcolt
    2,752
    119
    Jul 14, 2008
    Calgary, AB
    AMS3 likes this.
  5. 2quik6
    62
    36
    Jul 19, 2017
    Yes I had all of that removed already, nothing left on the hub/rotor. It would not budge even with some decent swings with the BFH... Also soaked in WD-40 for a bit, still no budge... Ordered a rotor puller good for 7 tons...see if that and the BFH gets it done in a few weeks....had to put it all back together as I needed the truck later today.
    AMS3 likes this.
  6. 96indyshaker
    96indyshaker Member
    40
    23
    Dec 16, 2018
    Auburn,Indiana
    If your rotors are the orginal there may be a clip over one of the studs. Or I've had some drums in the past that had rusted to the axel flange. Took a very big hammer to break them loose.
    Srt10650 likes this.
  7. SHO
    SHO Full Access Member
    420
    3
    Jul 14, 2012
    I would try adjusting the emergency brake shoes all the way down. They maybe be holding it
  8. Srt10650
    Srt10650 Full Access Member
    352
    296
    Sep 30, 2016
    Kiwi SRT10 and AMS3 like this.
  9. Kiwi SRT10
    Kiwi SRT10 Well-Known Member Supporting Member
    967
    1,000
    Dec 16, 2019
    New Zealand
    Let the park brake off hahaha:D:D:D
    AMS3 and SHO like this.
  10. 2quik6
    62
    36
    Jul 19, 2017
    Well the first sentence in my OP is "E-Brake is off"...so that ain't it. No clips left on the studs. Rotor would turn freely with both wheels off the ground, so I don't think the EB was holding it on at all. Most likely was rusted to the axle like 96indy mentioned. I let it soak in some WD40 and hammered it with a 10lb sledge, as best I could, had little swing room. But the puller did the trick fairly easily once I added heat to it.
    AMS3 and Kiwi SRT10 like this.
  11. Slitherbeast
    Slitherbeast Well-Known Member Supporting Member
    2,283
    35
    Sep 10, 2007
    Alberta
    Wire brush the center axle flange and soak it. I use a 3 lbs brass hammer along the outer edge's of the rotor and you got to be accurate and deliberate with every swing. Don't be shy! Hit the damn thing....
  12. Bad Azp Performance
    Bad Azp Performance Member
    56
    43
    Nov 9, 2021
    Las Vegas Nevada
    E brake may be off but you hsve to get the pads to retract.
    E brake has its own pads inside the rotor hub.
    After a lot of miles the get caught on the groove they make
