Seems as tho my so Kit has been so called "the same as all out there" well I will only say this one time as honestly it is not woth the time of going over time after time
I have done mainly suspension for probably 15 years or more, and that was it mainly suspension, with about the same time spent racing motorcycles , so suspension is one thing I do know alot about. So when those people can look at a vehicle, make adjsutments with no machine, and it come out perfect, then they can come and talk with me
So unlike the people that are trying to thro my kit into every other kit out there, I do care, Just ask amtrucker22, griffsrt, or spjrdc.And Carl I havent gotten back with you yet, as you will notice, I spent most of yesterday working on my engine, I havent forgotten you sir
Also it has come up that some of the trucks are unlevel after lowering, well the fact is nobody puts a tape measure on there truck untill after its lowered
if you put a spring or block that lowers the front or rear the "exact same amount" on both side,then it is unlevel ?
, then naturally it must have been unlevel before it was lowered.
I talked with many that will bump up an tell ya, theres is unlevel bone stock, most do come that way factory, but I have also gone back and for no charge either cut blocks or helped them in some way to get it the way they want, sometimes several times until they are happy
as far as solid blocks and being correct, well that dont take an engineer to do
its a very simple deal, ITS A FREAKING BLOCK! DUH!
Really how many ways can you do it?LOLOLOL
Maybe the unhappy person that dont like my "kit" or others should call eibach, ground force, or DJM and discuss with them about designing all there blocks since thousand of kits out there are wrong
but if ya'll want SOLID BILLET BLOCKS FOR THE REAR I can check on them, as I think they can probably be had for around $60 or so ,not $2-$500
but I never went that route as to keep YOUR cost down, so that anyone could afford a lowering kit:rock: I have allready had to go up on mine due to the rise in increase in steel parts, my price on u bolts alone have trippled:argh:
And as far as the member that started the thread last night, c'mon it was just a straight out thread pointed at me
and my kit , that was obvious, but thats ok
I have too many other problems to worry about than someone bashing my kit, and offering so called correct blocks for $500
The one thing I PROMISED when I started as a vendor is to do WHATEVER you guys wanted, and to be here , be it 3am , or 10 am, unlike other vendors we have had. And to help in any way, and so far I think I have upheld that promise:rock:
And Tone bo, it was good to talk with ya sir
Thats all ,will be back later to answer questions, momma just got home and I am taking my Little lady to lunch
