Who knows the body measurements? Towing?
A RC will hang over an 18' flatbed. I know a guy who towed one with an Escalade but he lost a little bit of paint on the truck to one of the trailer fenders. It is a VERY tight fit. If I were to tow mine on a trailer like that I'd just run with the fenders off. Your suburban will be able to handle the weight as long as you have a brake controller for the trailer brakes. If not don't even think about it. Your QC will hang off the back, not a big deal as long as you make sure that you get it far enough forward to have enough tongue weight so it won't sway uncontrolably. Depending on the trailer you may need a weight distribution hitch. If you have to pull it too far forward so that you don't have too much hanging off the back, you may end up with too much tongue weight for your suburban. Really you need a test fit before setting off down the interstate.
I tow mine in an enclosed trailer and it fits nicely in a 25' deck trailer. Pretty close to the fenders so I'm going to modify them slightly to get a little more clearance. Can either you or your wife fit through the rear window? On almost any trailer you won't be able to open the doors enough to get out. If you go out the back you can push that window close to shut in case of rain.
Joe
i towed mine to ohio year before last, backed it on there for the trip up there and pulled it on there for the trip back. pulled better on the way up there cause the weight was closer to the trailer axles. was a regular car trailer. fenders were in the way. hard to open the doors.
