bigike
Intercooler problem solved................
Thats what I figured also, cool setup though that is thinking outside the box:rock:eddie102870 said:same blower you got itjust has a different nose piece on it.
Prof said:Yup, that is the show truck (resides in N.J.) that Sean installed the side mount blower on just prior to putting mine on top...(Sean also installed a top mount on Mike McCardless's qc before mine).
This begs the question.....why did Roe abandon this for the top mount?...
so which way puts out more? is that less restrictive, but not with a smooth Idle?Prof said:Looks.
The traditional top mount was what people were screaming for...the side mount was too much like the Paxton...
that is pretty though. another question and sorry for hoin. does sean have the pulleys to go bigger I was only wanting to go 8 put so far all I have seen or heard of for ours was stock, 10lbs and 14lbs.Prof said:You need to ask Sean...I don't even know if he dyno'ed it...can't imagine that he didn't!
But it was a show truck not a street machine.
so then with out head work I would be able to actually get 10 psiProf said:He put a 10 lb on mine when we were at Westech. But it only pushed 8 due to the head work that I had done. I bet he could have one made for you...or just clean up the heads and use the 10 lb and get a net 8.
Call him Matt, I bet he can fix you up.
