- Joined
- May 13, 2010
- Messages
- 323
- Reaction score
- 0
What is the importance of a Wideband A/F sensor?
Is it worth it?
Should i be looking into getting a kit?
Is it worth it?
the one I suggest is the aem , it has a silver face or a black face, they seem to work the best and are better priced than the autometer which is around $100 more or so.1fast10 said:stinker do you have a guage that matches ours (oil pressure) sort of?
you have to weld a bung into your exhaust system adn the new 02 sensor will fit into there sirJimlah said:What contacts do you have to tap into for the guage to work?
JTS VENOM PERFORMANCE said:a wideband reads your air fuel mixture, and the mistake most make is lookin at it while driving down the road
the air fuel guage is best used to meter the mixture at wide open throttle,
it will let you know if you are running lean or rich.
now depending on your mods is whether it is worth it or not, to me I dont think anyone should be without one, especially if you are nos or forced induction
Jimlah said:So if you have JMB Catless Mids, you can tap into one of the unused O2 sensor holes?
thats the only time an air fuel guage is reading your mixture thru the rpms,34bud said:Good point Stinker about looking at the gauge while driving. I have thought many times while Im at WOT trying to take my eyes off the road to look at it. I have a Paxton and Im thinking about installing a light (simular to a shift light) so when the Paxton fuel controler turns on the pumps under boost the light stays on while their on if it goes off under WOT time to get out of it. I know its not fool proof but may help.
You're wrong on this one sir. Tony is correct in post #13. At idle or light throttle, the computer is trying it's damnest to keep A/F at the range indicated by Tony. So, an A/F gauge is pretty much worhless there. Were it's priceless is at WOT.Chuck B said:I will disagree with you. An AF meter will give you accurate readings whenever the engine is running. WFO is important but it is no better or worse at WFO or idle.
While not as noticeable with an 8.3L V10, driveability problems are more pronounced with smaller displacement engines. In the motorcycle world poor fueling at say 10% throttle at X,XXX rpm's can be very noticeable.
Additionally, what is considered optimal at WFO is not necessarily optimal at 65mph cruising down the highway. AF meter lets you know what the fueling is at a given throttle position.
Difference between an SRT10 and my GTR1400 is I can plug in my laptop and make minute fueling changes at any RPM and any throttle position. There's no easy software interface with Dodge ECU which greatly limits the effectiveness of having an AF meter for the SRT10.
Real world....I can program a secondary map for my GTR. Primary map is for performance. Secondary map is for fuel economy. Using my AF i can fully map/setup my fueling for both maps throughout all RPM's and TPS. Using a simple switch I can flip between those maps when I desire. With an SRT10 you can look at your AF Meter and say...hmmm, seems to be running rich/lean. Now what are you going to do? Oh, thats right, you're at the capable hands of a tuner. If you don't dyno your truck he can only approx what fueling your truck needs. He'll charge for each change and trust me he's going to error on the side of rich. Many tuners will only spend the time to dial in WFO and not all the other throttle positions.
Anyways....AF meter is only good if you do something with the info. At the very least a person could modify their vehicle and having the AF working know if they are running too lean thus possibly saving a major meltdown.
In the motorcycle world aftermarket company's are producing closed loop performance modules utilizing wide band o2 sensors to automatically 'remap' every time the vehicle is running. You input general performance parameters you want (hp, economy etc) and it will set up fueling and maintain that fueling parameter going forward. Bye bye tuner...
These are no different than what any modern vehicle comes equipped with from the manufacturer except these are adaptive and end user directive.
Silverbullet08 said:u can get the AI which monitors tons of temps and then add the wideband part to it. also u can get it to say srt
http://www.aeroforcetech.com/accessories.html
JTS VENOM PERFORMANCE said:the one I suggest is the aem , it has a silver face or a black face, they seem to work the best and are better priced than the autometer which is around $100 more or so.
but it doesnt really "match" or say SRT
Venom Power said:I got one of these AEM A/F gauges from Stinky. It's great and looks great up on the pillar next to the oil temp gauge.
