belgiumbarry
Fepony said:Not to worry...i got you covered. :rock: http://www.weldcraftwheels.com/Wide.htm
thanx :rock:
Roz-SRT said:The stock size over height is 31.5 inches tall.
Those are only 28.8" tall. Your front tires will be taller than the rears, unless you make the same compensation for the fronts. Looking at the truck, you're gonna notice 2.7" difference. . .![]()
Can someone explain the gearing ration thing and why it is better to have 4:56 than 4:10 by going with a taller tire?
chase said:Thanks. So what gear ratio is stock on the 05 RC. I find that I get to redline too quick in first...would a lower gear help me by going to a taller tire?
mopower1958 said:My rears are 325's on an 11.5 inch wheel. They are Toyo Proxes. The guy that did my wheels can do steel or aluminum.
Marc T said:YEP!!
325's on 11 inch rims. They will fit on the stock rim but will have a little more buldge in the sidewall.
I have a little bit of rub when she bottoms out, I never hear it it but is evedent from rub marks on the plastic well liners.
kool! i was lookin' at those...$300.00 a piece,OUCH!:nurse:Trainman said:Hey Sanchoba
I'm running an ECSTA STX by KUMHO, size 325/40R22 on my stock SRT-10 wheels on the rear. They look good but don't offer any more traction than the stock size tires.
