wifes homework thread this will be ongoin thanks for the help
Prof said:
Bridgette, there is a technique for responding to multiple choice questions it has several steps:
1. You must have read the relevant material prior to responding to the multiple choice questions.
2. You must understand that most multiple choice questions are vocabulary tests that require you to discriminated small differences between defined terms.
3. In most well designed multiple choice questions all but two of the responses can usually be deleted because they are not relevant responses (if you have read the assigned material).
4. Close reading of the question and narrowing of the response choices to two possible responses will heighten your percentage of success.
5. If you really do not know which of the two possible alternatives is the correct response, research has found that 80% of the time, if you have studied the material assigned, your first inclination will be the correct answer. The mind is a wonderful thing, its long term memory is pretty accurate if left to its own devices. The hazard is that many over think their responses and fail to prepare and then fail to trust their brain. I can show you examples on ever exam I administer, of situations where people have put down the correct response and then gone back and over thought their response and changed a correct initial guess to a wrong answer. Trust your impulses if you have studied the material.
Certainly yes, as I learned in college, these (mentioned by Roy) are precisely the steps I took to answer the first question.. It really works. The answer to the second question I already knew... From studying it years ago..
Django said:
This should be renamed "I'm cheating on my homework...! HELP".
D;)
I think that's why Roy pointed her in the right direction of proper steps to study and take a test :dontknow: ;) It was the true professor in him that made him do it :rock:
It worked for me when I took my RE test. I eliminated the two that were obviously NOT right and then worked with the remaining two ....
505'sFastestViper. said:
thank you all
bk
Got any more we can "help" you with :dontknow: :dontknow: :D
thjones3 said:
The only thing this thread is missing is Jeff Foxworthy! :marchmellow:
bwahahaha!....are you smarter than a viper truck owner!:marchmellow:
can you give me some ideas for a research paper 8-10 pages long with at least 8 sources for english 211 thank you bk
You need help again?
What interests you Bridgette?
If you are going to write a research paper might as well make it something you enjoy or something that is needed for another class. Why not make your topic work for several different purposes if you can.
There are eight or nine different types of essays. Once you decide on a general topic area be sure to decide what type of essay you are undertaking (Definition, Classification, Description, Comparison and Contrast, Sequence,
Choice, Explanation, Evaluation) be sure you decide what your form will be and be consistent in your writing.
General guidance: Once you decide what your topic will be and what the goal (type) is, begin your research...the library is the place to go...remember that the librarian works for you! Have them help you in doing your research. They will assist you in specifying your topic, narrowing and being sure that you use credible, current materials for your research. Capture your important data on note cards or on your lap top...use a single page for each source (with full bibliographical documentation at the beginning of the page. Be sure to differentiate between notes and quotations. When you write notes, paraphrase the information accurately, but do not copy the information word for word. Quotations should be in quotes with direct attribution to the source.
Once you have gathered your data, (data leads to more data and additional sources)...make sure all of your material is pertinent and falls under your specific purpose, then organize the body of your presentation...array the data (notes and quotes) in a logical and appropriate sequence (it will be one of many organizational types, i.e. chronological, problem/solution, spacial, cause and effect or topical.
In the process of developing the body of the essay, your introduction should reveal itself as should the conclusion...I always try to incorporate several things in the introduction: Attention getting device, with an explanation of the topic and a reason for the reader to continue reading the paper. A thesis sentence is critical.
The conclusion should also flow from the body of the essay. Re-emphasize the main points. A good conclusion should have a strong hook. A definitive statement that captures the readers mind and leaves them with a positive impression of the material presented.
Doing your research early is important, and be prepared to amend your direction as you discover new and interesting material...be objective in your approach.
One of the ways my students select topics is to sit down and read a good newspaper...read every story...see which ones capture your imagination...and then go see that librarian! Note that I said a good newspaper...pick up a Wall Street Journal, New York Times, Chicago Tribune, Washington Post, St. Louis Post Dispatch...have fun and enjoy the learning process.
And another one
"Conservation of energy" refers to the fact that _____.
a the entropy of the universe is always increasing
b the net amount of disorder is always increasing
c if you conserve energy you will not be as tired
d energy cannot be created or destroyed but can be converted from one form to another
e no chemical reaction is 100 percent efficient
Letter D
Damn, a "thank-you"...usually my students just give me the finger:dontknow: :dontknow: :dontknow:
You are more than welcome...and if you only want a topic...how about "The art of tattoos"?
