WTB : rear O2 sensors for 94 SRT-10
HOT RAM
Shenandoah Valley,Va
After re-installing my cats I get a O2 sensor code about every other time I drive the truck.
They were left out for over two years so they might be bad. :dontknow:
So I need the two (left and right) O2 sensors
Or a viable alternative :D
I got my from the local parts store for about $40 bucks. That might be the easiest thing to do.
Just not the cheapest ;) :D
i may try the non-fouler trick first///// what size do I need ?
HOT RAM said:
OOPS !!!!!!! typing too quick :eek:
I didn't catch that one :eek:
Around here you know some smartazz is waiting for a little posting error...;) .............far as your issue...take it to your dealer..may be under warranty for emissions..:dontknow:
I just take the easy route and buy them from the dealer...about $40 each...
What is your code? Cat inefficiency?
If so get 2 spark plug non foulers 14mm thread size, get the longer ones.
Drill out the center with a 1/2 in drill bit. screw those into exhaust bungs then the o2 sensor into those. Problem should go away.
On the Hemi trucks DC has a flash for the hi flow exhaust.
I thl try this first.Trying to save that $40/ea :D
Emissions systems are warranted for 7 years ,right ?
Might try this
Might try this
All they can say is yes or no....the StarScan will also tell if the sensors are working...your problem could be elsewhere..
