RedSrt007 said:
The reason for the low score in the Install / Instruction category, is due to the lack of installation material that is included (there was non
), now possibly at a later time there might be, but as of right now, you have to install "by the seat of your pants". By no means is it difficult, but once again, the low score rating was for no guide on the installation procedures
Thanks
Patrick
didnt think you needed em, since ya have one already
X metal billet shifter instructions
• Remove the 3) 5/16 head bolts holding your center console down. They are located under the rubber mats in the drink holders & the center tray
• Remove the shifter knob
• Slide the console over the shifter & set to the side after unplugging the 12v accy plug
• Remove the 5/16 bolts holding down the plate with the rubber boot over the shifter. Some of the bolts, you will need to pull the carpet back a little to get to them
• Remove the 4 bolts holding the shifter to the transmission
• Remove the rubber boot over the old shifter & reinstall it on your X-Metal shifter
• Clean the transmission mounting surface & apply a thin layer of gasket sealer to it.
• Install plastic gasket on top of it
• Install the shifter handle at a height that feels comfortable
• Install the shifter base & apply the loctite to the 8mm screws & torque to 14ft lbs
• Remount the console. The secret is to let the shifter do the work. When going from 2nd to 3rd just use the palm of your hand. Subconsciously you might move the auto alignment the shifter is trying to do. The lower height adjustments work better for racing use. It shortens the throw & centers the shifter
