X-Metal Shifter Gen X (modded) Re-List
Status
Not open for further replies.
LitemUp
The Looney Bin
I originally posted this For Sale a while ago, but decided not to sell. I ended up keeping the custom shifter boot and bezel. Since I listed the item with it I didn't feel right selling. So I decided to re-list, but this time without the shifter boot and bezel since I'm using it. You could always have one made if you want one at any good upholstery place.
Selling my X-Metal Gen X shifter it has been modded to reduce the rattle that usually is common with the aftermarket shifters. Shifter works flawlessly the only reason why I'm selling it is because I got a new Venom Shifter from Tony.
Shifter will come with all bolts as seen in pics.
**Custom rubber isolator and metal plate that helps reduce the rattle.
**Larger bolts were used with nylock nuts as well to make sure that everything remains nice and tight.
**Nylon washers were used on the bolt on the upper handle to further reduce noise.
To mount to the tranny you use your stock bolts and your stock shift knob also screws right on. $125 plus shipping. Shipping will be ruffly $20-$25.
__________________
Will the stock boot and bezel work with this shifter?
Status
