Prof said:Still wondering how the pcm flash will add hp in a RC??? Especially if you have a VEC II or III...
Are you asking me this question:dontknow:
Dave T(BADVENM) said:I know on mine it removed the wide open throttle timer delay. I dont think you can do that with the VEC.
Get Bit said:I shaved .8 with the DC StageII. In better air I think I could get almost a second. The only other thing I had was the magnaflow cat-back and that does not add much if any HP.
The truck is day and night with the StageII it's not a "feel it in the SOTP" it is a Kick in the ASS of your pants!
Prof, When you punch it, it should get it right now if your vec 111 took the delay out. If not it will take a second or two to get the power. I think.Prof said:Had no idea! Now how do I check to see if it is doing so on my truck? Stingray, can you chime in here?
Prof said:So that takes us back to the issue of a Stage II flash for a RC...if the VEC III deletes the WOT delay...what value is the Stage II flash?
Roy,Prof said:Am going to ask Sean...I don't have a hesitation that I can detect.
ViperTruck2933 said:...If you have the VEC 3 the only value in the flash is the temp fan control. The true value of the flash over the VEC is the the flash is plug and play and doesn't have to be setup by a tuner.
Correct.Prof said:This really helps...I guess the other side to the issue is that the non-tuner aspect of the Stage II flash is softened if you have need to change the tune...the VEC allows that to happen, the Stage II flash would have to be re-flashed by a tuner...and could not be done by the owner.
Now I think I am getting closer to the issue.
Bolt on mods won't make any difference. It's a generic tune that is designed to support any and all combinations of bolt on mods.:rock:BDR SRT-10 said:Interesting information... I've been pondering the Stage II flash as well on my '04 RC and wondering its true benefits... Is it best to have all your mods on (i.e. CAI, exhaust, cat-less mids, headers, etc.) then go for the flash???
jeffgilliam.2005 said:still for sale..???
