- Joined
- May 19, 2006
- Messages
- 3,128
- Reaction score
- 0
Going to be mowing about 2 acres. Any recommendations on brand? I'm looking for a slightly used (less than 100 hours) machine.
SilvrSRT10 said:If your looking for a used machine. Keep your eye's open on Craigslist. I found this but not sure about the brand or what price range your looking at. My suggestion is find your closest lawn equipment store (not Lowe's) and buy something from them. You will need parts and service down the road and it's best to deal with someone who specializes.
http://charlotte.craigslist.org/grd/1128998485.html
Yeah, I thought it looked a little small for 2 acres also. You can do a search on "ztr" or "zero turn". I think "zero turn" gets more hits.outnumbered said:Thanks Dave. I did see that one, but the deck is too small.
yellowfever#154 said:Best zero turn mowers I have ever run is a Ferris IS1500. Although they are quite expensive, around $9000 Canadian. For a very good quality yet inexpensive mower have a look at the Simplicity Javelin. The Simplicity is not quite as heavy duty as some of the more commercial type mowers but are very well build. If I can remember right they are about $4000 Canadian.
Just did a search and it appears the Simplicity Javelin is no longer, the Axion is a similar design.
http://www.simplicitymfg.com/products/zero_turn/axion/
http://www.ferrisindustries.com/pages/mower.php?product_id=29
Black1 said:Dixie Chopper, Kubota, John Deere (Commercial), John Deere ("Home Depot/Lowes model" zero turn.... but, you can also get them at JD independent dealers for the same price and get a good service plan)..... In that order.![]()
I had a JD rider from Home Depot, and it ran flawlessly for 3 years. My lot was only 1.5 acres, but the guy that built the home in the early 1940's was a golf course desinger. The grass was so thick and dense, it was crazy. I think he said the grass was "Miniverde" :dontknow:... I know if I let it go for more than 4" or so, it would bog down the triple blade deck and 23hp Kohler motor.![]()
outnumbered said:Going to be mowing about 2 acres. Any recommendations on brand? I'm looking for a slightly used (less than 100 hours) machine.
1qksrt said:Try adding a little more power if you want to mow quicker![]()
