info
inexpensive and performance dont go together unless you own a ford, or chevy, you sometimes can find a blower on here used for $3500 but may spend another 2k finishing it up. or new for 7k plus by the time your done
He said "good" :D
Then again, he also said inexpensive.
What's a good inexpensive supercharger
Well since we have a bunch of guys here that choose to joke around when a forum member asks a serious question ill take the time to answer your question...
A few options
1; Paxton supercharger not cheap new but you can find them used for a good deal
2; Roe supercharger while they look cool they are the worst performing charger and not cheap new
3; Procharger setup JMB Performance & Powdercoat, LLC. an awesome vendor on here!!!! as inexpensive as the paxton when its all said and done
hope you figure out what your wanting to do
A few options
I agree Procharger is the best, my friend's buddy runs 7's with his foxbody using a procharger.
JMB kit looks faaaaancy too :D
VERY NICE KIT
IMO, the JMB kit looks killer and has performance #'s that are hard to beat for the time and $ involved.
I dont think you can go wrong with Justin's Pro Charger kit, it performs , looks great and he can customize it to your liking( colours) of your choice before you get it! Put it in and done.
Description:
The first and only Do it Yourself 1000+ WHP
kit on the market for the SRT-10 Ram. Available
in pieces for those that want to spec out their
own parts or buy the entire kit and be ready to
go. Requires keyed crankshaft with upgraded Balancer.
Will not clear stock fan assembly. Not for stock
motors!!
Base kit includes:
ATI Procharger Polished F2 Blower (2700 CFM!!)
Billet 6061T6 Bracket System
2" Cog Pulley Drive system with crank, blower, and
idler pulleys, crank adapter, and belt.
All Stainless Hardware
Powdercoated finish on all brackets and spacers
Installation instructions included
$6,500
then another $3500
Front Mount Intercooler Setup:
-Enormous 1500+ CFM intercooler
-All Intercooler piping from Supercharger and to throttle body with powdercoat
-Tial BOV
-T-bolt clamps
-Silicone couplers
-Must send in your condensor for modifications.
-Modifications required to front bumper assembly
-All hardware and installation instructions
$2600
Electric Radiator Fan Assembly
-Huge Electric Fan
-Custom powdercoated shroud
-Thermostat/relay assembly with SRT10 specific wiring harness
$700
Air Intake Assembly
-Custom powdercoated heat shield
-High flow air filter
$199
$10,000 - super charger
pluse misc items and labor, thats not encluded the cost of the engine build
$10,000 + engine build
A Supercharger setup for stock or modified engines that
leaves room to grow. Designed to fill the gap between the
smaller superchargers on the market that are maxing out
around 700whp or less and the larger JMB F2 Setup that
requires a built motor. Featuring Prochargers F1-C model,
coming in at 1850CFM, this supercharger has the flexibility
to produce 600-950+WHP on your SRT-10 RAM and is the
only supercharger system on the market proven to do so.
The kit is offered in two forms, dedicated 8 rib drive (good
to approximately 10-12 psi depending on engine combination)
or 50mm Cog drive (good to 16+ psi depending on engine setup).
Base Kit Includes:
ATI Procharger Polished F1-C Blower
8 Rib dedicated drive system with crank, blower, and idler pulleys,
Huge 4.5" thick Garrett GT Core intercooler
powdercoat
Tial BOV
T-bolt clamps
Silicone couplers
Air Intake Assembly with custom powdercoated heat shield
Pulley sizes tailored to each combination
Price and Options: $7000 base price
And Viper is a
i am - i perfer Tony "JTSVP" over Justin, just my preference just like your Justin's "JMB" boy toy
i am pleased with Tony and his work/craftsmanship - does it really matter
i was just pointing out that there is ALOT more you need with the JMB kit then you might think - being realistic, not just saying you need this and this is wat it will cost you
going FI any FI's app is alot of $$ it not all back and white
