Psycho Mythic said:I'm a sucker for a good trade, what do ya have in mind?
FATJACK said:You know that truck just might look awesome with that silver cover on it..
eddie102870 said:pm sent
Psycho Mythic said:And that 25-28mpg is awesome...what programmer are u using?
Yours is an automatic? Is it built? I know the manuals hold the power much better, the autos go out pretty regularly...Smokey said:the trick is to keep your boost below 10psi and you will notice the milage. I am useing a edge with attitude, banks filter, afe intake elbow, banks blow off valve, and 90hp injectors, airdog 150 fuel pump. on 35's makes about 530rwhp when turned up on extreme, but with the edge on 2 and 3, i have towed 16500lbs out of san diego out the 8 with no issues in 4th (can tow in overdrive ) multiple times
the edge is a nice beginning tuner because it has gauges built in. i would not turn the tuner past 2 (tow mode) or it will destroy your transmission.
Smokey said:yea, i had mine built by a local shop out here, what was your truck used for before and was it babied? if so you can get a replacement single disc TC and call it good, thats the weak link in the tranny. they slip and over heat teh oil.
mines build with a 3 disc TC, blue race clutches, DD tranny pan was $4400 for everything, done by a local shop
Psycho Mythic said:my was used as a daily for a realitor, and hauled a boat a couple times. Your sayin the clutch is the weak link (manual)? What do you think of a smarty s-06? I got a good offer on one...
