Blakewilder said:I have it.....it sounds NICE! Stinker and Jack have heard it.
Could be different profiles altogether.... Or slightly altered... or completely different. Which is why I am seeking the specs.....RedRamRules said:So Mopar makes the comp coupe cam & a mopar performance cam? I assume the comp coupe is the more aggressive/powerful one?
HaulinAsp said:Pat do you have the specs on that stick? Does Mother Mopar suggest extra clearance on the piston tops for the valves?
Damn yet another question- Anyone have the cam specs on the stocker? And have the cams changed specs over the years?
LOL sorry for the interrogation but knowledge is power. LOL
Bone said:How about 1.7 rockers, springs, retainers (upgrades) with the cam?
Are they needed with the cam? If so, which cam?
ViperTruck2933 said:Comp cams makes one that's a little bit different grind than the comp coupe cam too. Mmmmtorque is running it.
I am sure he'll chime in when he sees this. :burnout:
Where did you find it & how much? Thanksmmmmtorque said:I'm running Comp Cams part #111-000-10 VIP3 2003UP Viper/Truck Special Roller
Gross lift Intake .528 Exhaust .536
Duration Intake 218 Exhaust 224
Lobe lift .330 and .335 with seperation of 114
Sounds much better than stock and gained around 25rwhp.![]()
Uhh, Comp cams Bro.RedRamRules said:Where did you find it & how much? Thanks![]()
