So im driving my 10 this morning and my cluster starts acting up?! On the odometer where miles shows that blinks...park brake blinking...airbag light goes on and off blinking and beeping everything else seems fine, radio lights. I checked my ground on my battery post and positive and seems to be good
Did you do anything in the truck recently? Radio or anything? I can't find much here. http://www.dodge.com/bodybuilder/2005sbbgl/docs/wd/dr/wiringdiagrams/8w40instrumentcluster.pdf There are 3 grounds it looks like coming from the cluster. I would think they are under the dash, probably all go into one connector that it bolted down somewhere. Might be a trip to the dealer. :dontknow:
Try disconnecting the battery, both pos and neg and let it sit for about 15 or 20 minutes, then reconnect. As wes mentioned, a dealer visit maybe in your future.
Most likely a bad alternator as SrtBrad points out. The alternator is not charging the battery forcing the vehicle to run off pure battery power. As it falls under 11.1 volts, or thereabouts, it begins to wreck havoc on the electrical systems connected to the ECM either directly or indirectly. My 2-cents.
Here are 2 videos driving ....... stopped at a redlight....http://s249.photobucket.com/albums/...on=view¤t=video-2011-11-07-07-00-47.mp4 driving on highway cruise 6th gearhttp://s249.photobucket.com/albums/...on=view¤t=video-2011-11-07-18-01-38.mp4
i disconnected positive cable off battery while truck was at idle in driveway to check if alterator is bad...truck stays on no problem went ahead and disconnected the negative side as well and truck seems to run fine alternator is doing its job so its not the alternator or battery....i have to have a bad ground somewhere imma have to take the cluster out and check harness make sure there re plugged in all the way follow ground connection maybe...
Imma take cluster out and check all 3 plug in connections wires etc. Before i make a trip to dealer...since a fuse blew once in cluster and i had to replace it once already. Good thing it was under warranty cluster is like $600 or so and they have fuses internally so if one has a short or blows need to change the whole thing
I dont think its that since...door switch only turns odometer on and its making not only the odometer blink but also park brake and airbag plus turn signals will be really staticly in cluster when turning either one all tho outside light bulbs blink normal without any issues
I use to think the same until that happen to me...and i took it to the dealer and apparently our clusters have like 3 fuses internally and if they have a short or go bad there is no way on replacing you have to get a brand new cluster which are pretty expensive IMO I only had to pay $100 deductible because of my warranty but they are like $600 or more i cant remember now. And I think what caused the short was actually my fault, I had wired something and didnt disconnect the battery negative cable.
I have to check my reciepts....also I think my warranty is no longer valid. but I drove it around today and nothing....everything working fine its gotta be something minor im just real picky, like everything to be just right you know. so imma first take a look at cluster and take it out myself( which i changed out the first time at the dealer since I use to work there before and I know the service manager and all the techs there) and just see if its that maybe the plug is not completely "clipped" in or something inspect the wirring...and if I cant seem to find nothing and it keeps acting up imma just take it in have them check for codes see if they can figure it out.
