Head Gaskets
Slitherbeast
Well-Known Member
Alberta
Has anyone tried the cometics .027" thick head gaskets? I understand they will raise compression about a full point! Just wondering if it is tune able on pump gas
Tearing the heads off is no big deal if you're doing a cam swap. The heads could then be gasket matched and polished and the springs replaced to match the cam. The cam,alittle bump in compression ,alittle port work ,roller rockers and hardened pushrods and some tuning,should be knocking on the door of 500 RW HP. It is alot of work but could be done in a couple weekends including some powdercoating . Just wondering if the pistons would take the extra abuse if the gasoline wasn't octaned enough. Highest we have here is 94 but with 10% ethanol.
nobody pays too much attention , but
our ported heads, cam , valve springs, push rods, oem tb, oem air intake and air filter thru an automatic, and on a sh$t dyno that was (as we have found out recently ) reading very low, its been tweaked some since then and shes putting out a bit higher now, but its not bad, our kit will probably run with cam , springs, push rods , gaskets, installed for around 3k
Nice smooooooth graph right there
Now that's what I am talking about!!! Exactly what I was hoping for! 500 and 500! Awesome!!
515 to 550? About what would it be without install? That'd be a worthwhile gain for the money:rock:
we are doing figures now, chris is comming up first of feb for an install, and we will use his for concrete results, after that I will have pricing on jsut the actual kit boss
Would the kit include a new program for sct tuned for the mods? Would one of your new t.b.'s be in one of the packages? Can't wait to see results :)
