Has anyone tried the cometics .027" thick head gaskets? I understand they will raise compression about a full point! Just wondering if it is tune able on pump gas
What kind of gains will that get you?
nobody pays too much attention , but
our ported heads, cam , valve springs, push rods, oem tb, oem air intake and air filter thru an automatic, and on a sh$t dyno that was (as we have found out recently ) reading very low, its been tweaked some since then and shes putting out a bit higher now, but its not bad, our kit will probably run with cam , springs, push rods , gaskets, installed for around 3k
cant seem to find the right sheet off hand, but closer to the 550 mark at the moment
515 to 550? About what would it be without install? That'd be a worthwhile gain for the money:rock:
we are doing figures now, chris is comming up first of feb for an install, and we will use his for concrete results, after that I will have pricing on jsut the actual kit boss
