moparviper
I just looked back at my service records. I had my transmission fluid and my rear diff fluid changed not even 10 thousand miles ago. Think it could be bad again?
With all you guys telling me that my mph is slow and my top end is slow. And my 60 foot times being good. It has to be they way i shift. Its like it get caught or hesitates when shifting. Also it struggles going into first gear when i stop and start to go again. But if i go into 4th then into first it slides right in no problem. Any ideas?
I was actually able to steal a rack from a mechanic at work and the trans. Fluid is full also. So that just leaves the synchronizers correct?
The mph seems a good bit lower than it should be for your mods, are you on the stock clutch? With a 1.75 60' time you should be well into the 12's, and yeah you don't really NEED 4.56's, I'm still running them
is your clutch fluid clean? replace your clutch fluid first...
seems like you're skirting the advice already given from ALL of us who've done this and assuming it's something major.
This is poor advice. The guys here have no idea what they are talking about. I'm sure your clutch fluid is perfectly fine, "because the mechanic at work (who didn't even look at the fluid) said so". What you need my friend, are new leaf springs and front lower control arms. I'm sure swapping out those parts will totally cure your problem.
You get away with 4.10's because you use a shorter tire than most people, remember when you ran the taller slick you actually lost time and mph.
I have tried putting more air in all the way up to 18 pounds and nothing has hooked as well as 12 pounds. I'm thinking that ill have to stay at 12 pounds since the otter parts are already smooth until i buy new drag radials.
The low air pressure may help you short time but it kills mph. you may be better off getting slicks or ET streets for the track. I ran 18 psi in my first Gen Lightning cutting 1.70 60's and ran low 11's at 115. I ran 11.50 x 30 ET Streets with 4.11's leaving at 3300 rpm. It was a 94 Lightning with a 408 and 150 hp NOS. 4500 lbs street trim. Dyno'd 380 on motor and 480 w/100 shot and a little over 500 with the 150 shot. Broke a lot of hearts from 97 to 01...:rock:
