Window switch.
Mopar
western colorado
For the past couple weeks my driver side window has been hit or miss. Sometimes it would work, and sometimes it wouldnt. Finally today I got in and nothing at all. All the other windows work fine. Where do I need to start?
I haven't worked on one yet, but from my experience the driver switches on most cars get gunked up over time.
If you are mechanically inclined I would carefully take the switch apart and make sure the contacts are clean.
I have the same problem. I have taken it apart and inspected (not cleaned) it and didnt see anything out of the ordinary. I think it might just be a crappy switch panel. Seems to be a rather common issue on all Rams.
Could be a broken wire in the rubber boot between the door and the body. Hear thats a common one as well but a relatively easy fix with a soldering iron
The passenger front window doesn't go down from the pass side switch. Does on the drivers side tho... Annoying.
I pulled it apart, cleaned it and put a little more contact grease on. Still nothing, gonna look through some salvage yards this week for a new master switch.
And by the the way it's a pain in the ass to get the switch covers off the actual knobs. Take your time if anyone else is gonna do it.
