Rear wing removal?
Wastelands Warrior
Wastelands of NJ
Hey folks,
Just wondering how involved it is to remove the rear wing. I want to get mine repainted and since the truck is being stored for the winter I'd like an idea of what is needed to get the wing off so I give myself enough time to go get it.
Thx
WW
two bolts on front edge from inside bed, then you slide it forward out of the rear posts.
use the tool kit that came with the truck - takes about 5 mins to remove - its easy
It's a 10mm bolt on each side or leading edge of wing (front edge) then you'll fist bump each side towards the rear of truck on the alignment pins. Gently remove once it comes loose. There is a bracket setup that allows you relocate to front of bed when not in use.
Install is reverse of above. :rock:
Get it, because he is from Jersey, like Jersey Shore.....never mind.....
