For the first 140K miles I left the truck exhaust stock. I'm about to install JMB cat delete mid pipes, B&B muffler and leave the rest of the exhaust stock. More flow does not always mean better performance...
Great move on the exhaust..:rock: Why did you wait so long?
B&B testing showed that the rear muffler behind the axle is more restrictive than the main muffler. Also, why have 3" mids and muffler, then drop to 2 1/2 tail pipes?
Question: If more flow doesn't mean more HP, why do the rails, funny cars on down, run straight out, headers open, no mufflers. Why wouldn't they have a complete exhaust system, muffler, exhaust pipes, etc. Why are we buying headers & most of us running 3" instead of 2" exhaust. I need to know if I'm wasting my money.
More or "additional" flow can mean more H.P. depending on application. On the Top Fuelers it's a moot point. Thay are blown and consume large amounts of fuel (up to 1.5 gallons a second)...Thus exhaust flow rate exceeds the abilities of ANY type of collector. Also, with this much flow and unburned fuel exiting the "zoomies", secondary combustion occurs at the pipe exit creating as much as 2500 pounds of force. Thus the shape and angle of the pipes is utilized for vehicle downforce, stability and believe it or not propulsion!!:rock:
Unfortunately, our big ol' trucks are just too heavy and inefficient
. We need some back pressure to generate as much power under peak (torque), for as long as possible to push em' around. Pick and choose your mods so that you maintain that huge benefit. Some cam, head and header combo's push the powerband up the rpm scale at the cost of low end thrust. If all you do is run it from 4000-6200 r.p.m. at the strip... that works. In the real world, the hand of god pushing 5,000+ pounds right off idle to 5,500 is a wonderful thing.
I'd pick a combonation that has been dyno proven to work best in that environment with your combination. Of course, overall sound and drone (or lack there of) may override outright flow.
It looks to me like you already have one of the best systems avaliable. Keep it.
Cheers!
