Lol.. why?
I knew it was wrecked..
And it's not as bad as I expected.
Plus there is nothing that will be non repaired or customized.
Being I have a shop and fix cars this doesn't bother me a bit. I've fixed much worse.
The only reason it was totalled was due to the frame damage, it's all a matter of cost vs value, I've seen vehicles get totaled for $1000.00 in repair before.. Heck I had a spotless Cavalier one time that had 60k miles on it, it was a wreck I fixed for myself to drive around, I got into a fender bender, it needed a bumper and a fender and a condensor, they totaled it, I bought $200.00 in parts and it was as good as it was before the first wreck.
If you look at the truck you will notice the doors were not even touched, which was one of the things that was confusing me, you would think with a salvage title the doors would have been destroyed, but it was all frontal..
You also have to consider the high cost of parts just because it is a SRT, my cost on the cooling fan assembly is like $900.00 add a SRT frame and a little labor, this is a expensive repair.
I worked a shop one time that replaced frames on nearly new trucks all the time from collision damage, it wasn't a big deal but if the truck was over 3-4 years old it would get totaled, same damage on one truck to the next, but one gets a salvage title and one doesn't because it has more value..
If this same damage was done to this truck right off the lot it would be considered acceptable to repair, but since it's older and the value isn't the same people get weird about it. I'm sure a lot of you are driving SRT's that were once damaged in a accident, some may not even know. As long as it is fixed properly what difference does it make.
Think about this, after I am done customizing this truck and cutting into the frame and doing what I am doing to it, the cost to bring the truck back to stock would be enough to total it as well. You would have to buy yet another frame, new front rails since I cut them up,a axle since I cut the mounts off, a complete firewall, which probably isn't even available.
But because the insurance wasn't involved it's not even thought about.
If that guy wrecked this truck and didn't notify his insurance it would still have a clean title as well. I do however know exactly what I have as I'm rebuilding the whole truck.
Carry on: :chain:
