Auto Rod Technologies Parts Runner
Discussion in 'Viper Truck Builds - Project Logs/Recent Mods' started by autorodtechnologies, May 27, 2014.
  1. 10-1=9
    10-1=9 Full Access Member
    1,735
    4
    May 21, 2014
    Allentown Pa.
    maybe a company that sells vintage air retrofit / custom AC kits might be able to hook you up with some lines or parts to build your own.
  2. autorodtechnologies
    autorodtechnologies Full Access Member
    294
    Sep 2, 2013
    SW Michigan
    This was my initial thought but from what I saw while browsing online they have different ends.. that being said I plan to call them but I figured I better have everything in place just in case they can make them for me, because then I can give them the measurements vs. saying. oh I can get them in a few weeks. lol.
  3. BAD SNAKE
    BAD SNAKE Full Access Member
    994
    May 21, 2011
    DC/MD/VA Area
    Nice work boss. The fender liners are sweet and you delivered on those. I believe Charlie is doing a set but a little different. You have some nice metal working skills.
    Most of the wiring should be pretty easy for you to hide. As far as the abs brake module I moved mine to the frame rail under the drivers door. I'm still working on the a/c lines my self I wanted them to be hidden as much as possible. Keep up the good work.
    [​IMG]
    and top view
    [​IMG]
  4. autorodtechnologies
    294
    Sep 2, 2013
    SW Michigan
    I made the decision today to mount the ABS as in you're picture, and as of now other than the battery relocation it looks like it will be about the only wiring modifications I'm going to have to make. Figured out where I'm re-locating the computer today, which was one of my big worries, but I am lucky that I don't have to re-wire anything and it all seems to fit really well where I put it.. I'll have to post pics up as I progress.
    Want to sell a matching copy of those braided brake lines? They look really good.
    Nice looking engine bay!! I'm actually not trying to hide my A/C lines, I'm trying to mix things up between factory looking and custom, proving to be a juggling act. lol..
    Thanks for the compliments,, Hopefully some more pics in a day or two, things are starting to come together.
  5. autorodtechnologies
    294
    Sep 2, 2013
    SW Michigan
    OOOOOOOOOOOOPS!!!!!!!!!!!!!!!!!!!!!
    [​IMG]
  6. VPRPWRD
    10,836
    10
    Mar 28, 2012
    PA
    You did yourself a favor, they would have leaked anyway if you didn't do that. :D
  7. 10-1=9
    1,735
    4
    May 21, 2014
    Allentown Pa.
    If it's the A/C line- oops maybe. If it's engine oil cooler or power steering- you want to replace them any way. Dealer wanted $250 just for the 2 ends fittings on the power steering line coming out of the pump. They (dealer) sold me a new hose but never told me I needed the ends to replace it. I just bought the power steering set from JTSV performance. Cost me $260 for both pressure lines (pump to fan & fan to rack) with priority shipping. They give you a lifetime warranty. With your skills should be able to build your own. You probably could make a piece of garden hose look good!
  8. autorodtechnologies
    294
    Sep 2, 2013
    SW Michigan
    ROFLMAO on that last comment, It's the oil cooler line and from the way it sounds everybody has problems with them so I guess I'll have to do another upgrade.. lol..
    Should be seeing a lot of progress on this one in the next month.. Stay tuned.. :)
  9. autorodtechnologies
    294
    Sep 2, 2013
    SW Michigan
    I'm upgrading to a jmb fan with new lines so that part is also taken care of..
    Am I missing anything else that I should be doing?
    Reliability is key on this one.. Right after it's finished I'm driving to PA for a show.. what a way to find any kinks..
  10. 10-1=9
    1,735
    4
    May 21, 2014
    Allentown Pa.
    I read a few threads about the stock (SRT only) power steering pump putting out to much pressure when the hydro fan is bypassed. Guess it would give us some kind of groaning noise. I would think you replace it with the stock pump off any other Ram. Justin from JMB should be able to help you out if you call or email. He got right back to me to answer my questions.
  11. bmxam962
    bmxam962 Full Access Member
    1,611
    Feb 22, 2012
    Powder springs, Georgia
    You can not use a stock ram pump but I am trying to make a gen 4 viper pump work which is designed to use a electric fan good luck
  12. autorodtechnologies
    294
    Sep 2, 2013
    SW Michigan
    I ordered the fan and stuff from him and sent him a email to figure out what I need to do.
  13. autorodtechnologies
    294
    Sep 2, 2013
    SW Michigan
    My fan also made a loud noise on start up but it is pretty beat up, most of the mount points to the fan are broken.. over all it's in horrible shape, whoever re-built this truck before didn't want to spend the price for the new fan.
  14. 10-1=9
    1,735
    4
    May 21, 2014
    Allentown Pa.
    We'll this would be a good time to do it then. Haveing troubles with my fan also. Only seems to work on low. The shop said it looks like the ECM is not turning it on high especially with the A/C on. You would think it should be on high with the compressor running.
  15. Ironhead
    Ironhead Full Access Member
    11,306
    Jan 14, 2008
    h-town
    Your shop does not know crap about vipers take to someone else
  16. 10-1=9
    1,735
    4
    May 21, 2014
    Allentown Pa.
    If it were only that EZ! No shops in my area are viper experts. Mutch like most things (cars,trucks,4X4's,H-D&other bikes) in my life that I end up working on or with I must become the expert on it. I'm ok with that! I'm always willing to learn from somebody knowledgeable. The problem is weeding out the nubs that don't know anything.
    Sorry about side steppn your thread.
  17. Yellow venom
    Yellow venom Boosted Venom Supporting Member
    7,800
    Jul 28, 2007
    Edmonton,Alberta,Canada
    You have an AMAZING build going on!! Looks very well made, I would like to go air ride some day, what would it cost a guy (aprox) to four link the rear, c-notch the frame and the control arms and mounts up front???
  18. autorodtechnologies
    294
    Sep 2, 2013
    SW Michigan
    I would have to sit down and add everything up but their are a lot of variables, for instance I went with a nice air control system, that alone was like $1800.00 add compressors tank and all the suspension parts.. I'm sure I have 5k into all of that, also have to get a fuel cell as it's lower than the frame.
  19. autorodtechnologies
    294
    Sep 2, 2013
    SW Michigan
    Making some good progress on the back half.
    [​IMG]
  20. ZCx
    ZCx Active Member Supporting Member
    9,803
    19
    Sep 13, 2007
    Big D
    :rock::rock::rock:
    so ya moved the axle forward???
    is the ride height goin to be when the Watt's link rods are parrallel to the ground???
