Lloyd mats
Sammy11
Belgium
Just got my Lloyd mats , only problem i see is that i cant go full throttle anymore because the Lloyd mat goes under my throttle pedal...
the OEM mats does not get under the pedals.:confused:
is that normal with these mats or do i get the wrong ones...???
Whats the part number?? I had those in my RC and never had a problem, I'll look for pics and see if they look alike.
They do go under the peddle. Won't slow ya down a bit ;)
If anything you'll be faster........looking :)
I have a set too but I can't keep it under 100..so I don't see a problem..;)
Put the mat in, then have some one sit in the truck & floor it (engine off) while you check the throttle body. See if the t cable holds it open it all the way. That would tell you for sure.
My mats sit the same way with no problem and I thought the same thing. I moved the pedals also with no change in the the throttle also
TB dont open all the way when flooring...:confused:
so the mats are to big imo.
see the diffrence in size ! ! !
If the TB opens all the way without the mat I would return them. If not you have another problem like a stretched cable.
hmmm...put the wifey in the truck today , she floored it and with the new mats TB opens all the way...:confused:
Give her the keys to the 10 & you drive her vehicle. Keep us posted on her times thru the quarter.
