Removing Ground Force lowering blocks
The problem is that I can not separate the block from the spring. I have tried just about everything except a grinder.....
I looked at the Ground Force web site, I can't see the bolts in their kit. Are you sure this isn't a shade tree lowering job? :dontknow:
So what is the solution then since you posted?
according to you and most others, you are the doctor, the originator, the first all of first alls? So I figure you are now the doctor of the site , so you should be able to kick it out asap, I am just the copier, so now I just like comming here stopping in to read the comics :D take care, and best wishes
Shade tree...?? Is that a brand?
The car is equipped with ground force shocks so I assume the blocks are the same brand....
Shade tree is a back yard mechanic. And I use the word mechanic very loosely.
Is it possible that the blocks were tac welded to the axle? Some kits actually recommend that or to weld them on real good because of the torque these trucks put out.
