KyleB
Currently I have the 2/3 drop from Tony and was wanting to go a little lower if possible.
DJM has 2 & 3 inch drop control arms for the front, and Michigan metal works now makes a 2 inch drop spindle so getting the front down wouldn't be an issue. I would probably buy a 1 inch drop spring from Tony, and either do the 2 inch drop control arm or spindle to get the front down 3 inches.
As for the rear, getting it any lower looks tricky. How big of a lowering block can you run? Can you use a lowering block with shackles? Could you get a 3.5 or 4 inch drop without shortening the drive shaft or doing a c notch? Or perhaps pull out a leaf?
Just rolling around some ideas.
