NO COMPRESSION in #1 cylinder SRT10
shouldve just removed the In/Ex rockers and installed a hose into the spark plug hole and used a air compressor and problem found, if rings = hissing from crankcase, throttle body hissing = In valve / seat, Tail pipe hissing = Ex valve/ seat
FIXED for only $800.00 It was a defective intake tappet that kept the intake valve from opening. The spring inside was shredded.
