blown motor.... now what
evobuilder
Austin, TX
I have a pristine 05 standard cab SRT10 with 88K miles and is stock except black KMC wheels. I blew my motor today (not evemn doing anything fun, just driving normal).... but it's soo bad it punched a hole in the block.
I think I am going to just sell it but have no idea what it would be worth with a blown motor. Any info would be greatly appreciated.
Thanks!
If you part it out you will make more money. People need parts
Thanks!
id give you 5k
Someone with the smarts on this.....what the heck could cause this to just blow? I'd be sick.
Thanks!
Engine is stock? No aftermarket goodies?
Cylinder 1 or 2?
it's always number 3
not sure
haven't had a chance to climb under and check out the carnage.... too busy crying tonight (not really, but sorta)
I wish.....
its the catastrophic grinding of metal parts and seize that makes me only wish an oil line came loose.
Get it to a shop or pull the motor to see the true damage. You can't make an educated decision without knowing what has been done.
Might be time for:
1. Rebuild engine
2. New to you used engine
3. Sell as a shell
4. Pull it apart piece by piece and part it out (you better have some room if you want to do this)
I will raise the bid to $5200
Might be time for:
1. Rebuild engine
3. Sell as a shell
I think he can see the true damage through the hole in the side of the block and not spend money on a dealership trip. :D
What took you so long to get here? :D
Haven't been checking my phone or computor but about once a day now. Been pretty busy and kinda got burned out for a bit cruising the web. I'm sure you know what I mean.:D
