sinus19
- Joined
- Sep 5, 2014
- Messages
- 589
- Reaction score
- 0
Hey guys.
first off.... The beast just hit 100k Miles
:bawling:... Bought it with 72k miles though and rebuild the motor at 78k nothing but good memories and a few wins under its belt with me
So anywho, I will be doing the 100k Maintenance essentials. (already has all new clutch and hydraulics, new motor, tires and new spider gears with outer wheel seals.) Next on the list is the front end. The steering is quite sloppy and loose. So im going to be doing front end. Bought New outer Tie Rod ends, Lower Ball joints, Upper Control Arms, ALL new bushings (power steering rack, sway bars front and back, leaf springs and control arms, and new leaf spring bump stops) from Tony. Also got a leveling block :rock:
With that said, I read that our Alignment Specs are different (more aggressive) then regular rams? has anyone gone with a different Alignment Spec for better handling? Also i will be on OEM shocks.
