WTB 6 speed parts. Going 6 in a QC.
here is a rundown of your list,... I'm almost there!!
SCT tuner CHECK
RC tune CHECK
6 speed pedals NEED
T56 tranny CHECK
T56 tranny bolts CHECK
T56 tranny mount CHECK
Floor tunnel NEED
Clutch master and slave CHECK
Clutch CHECK
Flywheel CHECK
Clutch pedal safety switch HOPE ITS ON THE PEDALS
Shifter CHECK
Shifter bezel CHECK (yellow fever one too!!!!!)
Steering column shroud NEED
Driveshaft Think I got enough to build it will see
RC engine wiring harness* Making my own
Dang sorry I haven't gotten around to sending you the driveshaft info. I'll set a reminder in my phone right now to text it to you ;)
The tranny mount is the same on rc and qc on the 05. 06 is different. You need the little bracket that should come on the t56
For the wire harness all you need is a wire from autozone that plugs into the reverse switch and splice it in the factory qc tranny connection.
Wtf is a floor tunnel?
Drive shaft is from here
Driveshaft Specialist Inc
And yes the neutral safety switch is on the stock parts unless you get it used from a wrecked one. But rockauto as them.
Anything else just ask or never nevermind. Ive only done a few conversions.
SCT tuner CHECK
RC tune CHECK
6 speed pedals NEED
T56 tranny CHECK
Floor tunnel NEED
Clutch CHECK
Flywheel CHECK
Shifter CHECK
Was that you that bought that T56 from X2 on eBay with 12K miles on it?
I have a Spare shaft but I had a vibration with it, only had it on for 1k miles might of just needed to be shimmed idk I switched to carbon fiber
Pm me what you gotta have for it. I think I have got all the needed parts to build an aluminum one. But I won't know for sure till the Trans arrives and I can check the yoke
Is there any special wires I gotta run for this switch? Or is there a plug tucked under the dash somewhere?
I didn't know it was on eBay but I did get mine from X2 and said it had 12k miles. What was it on eBay for?
Yup that was the one. I had been waiting for that transmission for months trying to get my funds together. Oh well.
Congratulations! :)
Congratulations! :)
Dang sorry bro. I was pointed toward them on the FB and I just called them up and they had it and two others for sale but the others had more miles. I bought this one with bellhousing, clutch, hydraulics, flywheel and all
SCT tuner CHECK
RC tune CHECK
6 speed pedals NEED
T56 tranny CHECK
Floor tunnel NEED
Clutch CHECK
Flywheel CHECK
Shifter CHECK
what does a yellow fever shifter bezel look like??
I'm just excited that it will match the rest of the truck. Lol
X2 has a clutch pedal assembly on eBay right now $200 shipped.
Hehehee I bought it this morning when they called to confirm shipping the Trans. Got it for 175 and they just threw it on same pallet so no shipping.
I went back and found the Trans on eBay they was askin 2500 plus shipping. I got the Trans with clutch flywheel and bellhousing bolts and hydraulics for 3000 so it wasn't too much more for all they tossed in.
Alright so I bout got it all gathered up. I will need the dash pouch that replaces the cup holders, I need the little power port for the console, I'm almost positive I need a pilot bushing for the crank and I think I got it all.
