6speedquadcab
NorCal SF Bay Area
Maybe a complete tune up is in order.
Unless that rodent was smart enough to swap around the plug wires they are in the correct spot. The coil pack and wires are numbered correctly. I was verbally told to take it for a drive and the computer will be reprogrammed. What could happen if i did that with it feeling like its misfiring?
Guess I'll have to check again. Pain in my sunday evening a$$. Which relays in fuse box should be checked? Just incase its one of them.
The coil pack i replaced was the forward one closest to the front with four wires going to it because those were the wires that were chewed. the codes thrown were P0352 and P0353 but that coil pack i replaced dont go to the #2 or #3 cylinders. Since there are only 5 primary circuits which cylinders are tied into each other? I am thinking i will have to replace the other coil pack aswell.
Rodents have become a pain in my rear. Something chewed thru my coil pack wires and knock sensor wires. Check engine light came on and had codes P0353 and P0352 pop. I repaired the connectors and put everything back on and started the truck. Truck feels and sounds like it is misfiring. So i replaced the coil pack that has four wires going to it. Again i started the truck after putting everything back on and the codes remained. What do i have to do to fix the issue? Truck is a 2005 Quad Cab
I NEED MORE POWER SCOTTY!!!!! It's almost 10 am there so answer your phone dude! I think I left a message on your phone as I'm not sure if it's still your number. The voice on the answering message said to leave my info but the voice (although sounded familiar) never said who it belonged to. I think it may be time for me to take a drive up into Waco soon.
