I saw her in the movie 1 million years BC when it was in theaters.
I think she was the only one in that movie.
All I saw anyway as a young teenage lad.
LMAO!!!!!!Keep practicing.
Soon you could build your very own Corvette.
I could make a plastic truck even hahaha What about an SRTvette lolKeep practicing.
Thanks, but we shall see if it works first. I cut rings off a plastic vacuum cleaner pipe and stuffed it full of fibreglass. I can't pull them off so I figure that should hold. I have just finished using Araldite to epoxy glue the tags/spades on the leading edge. Fingers crossed.I tried a fiberglass repair ONCE and it certainly didn't look as good as yours.
Hey Ronnie, got a question. Sometimes when I floor it in first gear, and it's shifting into second, there's a second of hesitation, kinda like pushing in a clutch to shift. My SLT did the same thing, what causes that?I tried a fiberglass repair ONCE and it certainly didn't look as good as yours.
Then a week later rebuild the transI'm assuming you have an automatic.
It's called many things but it is designed to allow your transmission to live a normal life by cutting power just before it makes the 1-2 shift. Torque-Management is probably the most popular term for what you are describing.
If you get a tune, it will eliminate that and by far it is the biggest bang-for-the-buck performance improvement you can make in a Quad Cab. Somewhere around 85 lbs. ft. of torque is unleashed in a really usable rpm area and it's a HIGHLY recommended mod for the QCs.
Got a new deal on the house last night. Maybe this time we are sold and movingThe tranny will survive with the new tune and stock power levels.
I wouldn't try towing and using wide open throttle with the tune nor too many passes with drag radials.
Nor would I want to drive a QC without having a tune.
The difference is enormous.
My 2 cents.
yes moving to a place called Pleasant Point about 20km inland from Timaru in the South IslandAre you staying in NZ?
Best wishes, buying a house can be stressful.Got a new deal on the house last night. Maybe this time we are sold and moving
I really like this "stuff" and have since I was in my early teens.
Although I've changed lots of components, most of the driving is part-throttle (no full throttle) for weeks at a time; like you said, super-cool to just go out for drives.
Looking back, headers were likely the biggest expense and didn't seem to make as much difference as I thought they should, particularly with aftermarket heads, more compression and a semi-aggressive cam grind.
Our weather here allows for only 117 frost-free days in a year. VERY little time to track-tune or enjoy the motorcycle. But no killer pizza-sized spiders and (2) varieties of poisonous snakes. Even they are smart enough not to live here.
