My Volant CAI
Discussion in 'New Members Section' started by Kiwi SRT10, Feb 9, 2020.
  1. rottenronnie
    3,178
    475
    Jul 4, 2006
    Calgary, Alberta
    I saw her in the movie 1 million years BC when it was in theaters.
    I think she was the only one in that movie.
    All I saw anyway as a young teenage lad.
    Kiwi SRT10 likes this.
  2. Kiwi SRT10
    Kiwi SRT10 Active Member Supporting Member
    358
    241
    Dec 16, 2019
    New Zealand
    I am repairing the main mounts for my hood scoop with fibreglass so far so good. Have marked the hole centres and next days off I shall finish it off. I found this neat product from ADOS that has fibres in the resin.
    AMS3 and rottenronnie like this.
  3. rottenronnie
    3,178
    475
    Jul 4, 2006
    Calgary, Alberta
    Keep practicing.
    Soon you could build your very own Corvette.
    Kiwi SRT10 and AMS3 like this.
  4. AMS3
    AMS3 Active Member
    304
    107
    Aug 8, 2019
    Savannah Ga
    LMAO!!!!!!
  5. Kiwi SRT10
    358
    241
    Dec 16, 2019
    New Zealand
    I could make a plastic truck even hahaha What about an SRTvette lol
    I figure to get a new scoop was going to be in excess of $1200NZ. I don't have that sort of money.
  6. rottenronnie
    3,178
    475
    Jul 4, 2006
    Calgary, Alberta
    I tried a fiberglass repair ONCE and it certainly didn't look as good as yours.
  7. Kiwi SRT10
    358
    241
    Dec 16, 2019
    New Zealand
    Thanks, but we shall see if it works first. I cut rings off a plastic vacuum cleaner pipe and stuffed it full of fibreglass. I can't pull them off so I figure that should hold. I have just finished using Araldite to epoxy glue the tags/spades on the leading edge. Fingers crossed.
  8. AMS3
    AMS3 Active Member
    304
    107
    Aug 8, 2019
    Savannah Ga
    Hey Ronnie, got a question. Sometimes when I floor it in first gear, and it's shifting into second, there's a second of hesitation, kinda like pushing in a clutch to shift. My SLT did the same thing, what causes that?
  9. rottenronnie
    3,178
    475
    Jul 4, 2006
    Calgary, Alberta
    I'm assuming you have an automatic. :)
    It's called many things but it is designed to allow your transmission to live a normal life by cutting power just before it makes the 1-2 shift. Torque-Management is probably the most popular term for what you are describing.
    If you get a tune, it will eliminate that and by far it is the biggest bang-for-the-buck performance improvement you can make in a Quad Cab. Somewhere around 85 lbs. ft. of torque is unleashed in a really usable rpm area and it's a HIGHLY recommended mod for the QCs.
    AMS3 and Kiwi SRT10 like this.
  10. Kiwi SRT10
    358
    241
    Dec 16, 2019
    New Zealand
    Then a week later rebuild the trans
    AMS3 likes this.
  11. rottenronnie
    3,178
    475
    Jul 4, 2006
    Calgary, Alberta
    The tranny will survive with the new tune and stock power levels.
    I wouldn't try towing and using wide open throttle with the tune nor too many passes with drag radials.
    Nor would I want to drive a QC without having a tune.
    The difference is enormous.
    My 2 cents.
    AMS3 likes this.
  12. Kiwi SRT10
    358
    241
    Dec 16, 2019
    New Zealand
    Got a new deal on the house last night. Maybe this time we are sold and moving
    AMS3 likes this.
  13. rottenronnie
    3,178
    475
    Jul 4, 2006
    Calgary, Alberta
    I hope it works the way you'd like.
    Good to see things are moving around a bit.
  14. rottenronnie
    3,178
    475
    Jul 4, 2006
    Calgary, Alberta
    Are you staying in NZ?
  15. Kiwi SRT10
    358
    241
    Dec 16, 2019
    New Zealand
    yes moving to a place called Pleasant Point about 20km inland from Timaru in the South Island
    Just waiting for new agreement on the same house we were going to buy last time before lockdown
    AMS3 likes this.
  16. rottenronnie
    3,178
    475
    Jul 4, 2006
    Calgary, Alberta
    Good Luck to ya!
  17. AMS3
    AMS3 Active Member
    304
    107
    Aug 8, 2019
    Savannah Ga
    Best wishes, buying a house can be stressful.
  18. Kiwi SRT10
    358
    241
    Dec 16, 2019
    New Zealand
    Next problem I am solving is the damaged firewall insulation and sagging conduit. As per pic. Will post pics soon of the much more tidy under hood
  19. Kiwi SRT10
    358
    241
    Dec 16, 2019
    New Zealand
    All Done. Glued crap to firewall and then riveted the ducting snug to the firewall also holding the crappy stuff on.
    20200606_114522 (1280x1280).jpg 20200606_115712 (1280x1280).jpg 20200606_115819 (1280x1280).jpg 20200606_115834 (1280x1280).jpg
    TrailMix likes this.
