Project Cottonmouth
Discussion in 'Viper Truck Builds - Project Logs/Recent Mods' started by Tincup, Jul 6, 2014.
  1. Tincup
    Tincup Full Access Member
    221
    106
    Feb 3, 2014
    MA.
    AMS3 and 68charger like this.
  2. edssrt10
    edssrt10 New Member
    2
    3
    Feb 22, 2019
    Nice!!!!
  3. VIPR PWR
    7,608
    2,957
    Jun 12, 2007
    FL
    Tincup likes this.
  4. AMS3
    AMS3 Well-Known Member
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    A labor of love, no doubt. I'm new on this forum, and noticed you started five years ago. This project will be a show stopper when finished. Good luck!
  5. Psycho1122
    Psycho1122 Full Access Member
    1,061
    123
    Jan 3, 2010
    Very IMPRESSIVE work. Great detail and engineering.
    Cheers!
    Tincup likes this.
  6. Tincup
    221
    106
    Feb 3, 2014
    MA.
    Finally Done....
    20201107_121716.jpg 20201107_121656.jpg 20201107_121614.jpg 20201107_121656.jpg 20201107_121614.jpg
  7. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Great Job!!!
    That interior looks awesome.
    What's the curb weight???
  8. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    Tincup likes this.
  9. Tincup
    221
    106
    Feb 3, 2014
    MA.
    Haven't driven it yet, having some cooling issues....
  10. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    What's going on with it?
  11. Tincup
    221
    106
    Feb 3, 2014
    MA.
    I'm not getting any coolant flow through the radiator. At first I thought my new thermostat was not opening, so I removed it and boiled it on the stove, and it worked just fine. Then I put the thermostat housing back on (no thermostat) and ran the truck, I didn't see any coolant movement in the rad, so I thought it was the water pump. I pulled the water pump and it was like brand new (probably the original) couldn't find anything wrong with it. So now I have no idea what it could be. Possibly some kind of blockage? Possibly an air pocket (should still see water moving). The rad is brand new, hoses are new. If anybody has any suggestions, I would love to hear them...:(:mad:o_O
  12. 68charger
    68charger Active Member Supporting Member
    325
    29
    Jan 1, 2010
    alberta ca.
    If you changed or deleted any accessories which changed the belt orientation could the pump be turning backwards?
  13. Tincup
    221
    106
    Feb 3, 2014
    MA.
    Thanks, but nothing has changed. I even downloaded the belt diagram just to make sure I put it on right.
  14. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    Did you bleed the system at the thermostat housing? That's a problem I had when my radiator was replaced. I couldn't get the bleeder valve opened due to age, so I did the bleed by squeezing the upper hose, putting my hand over the radiator cap opening, and releasing the hose. Spent about 10 minutes doing that, it finally drew the antifreeze from the overflow jug, into the system. Didn't have any issues after that. Could there be a blockage in the new radiator? Ronnie might be of some help.
  15. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    Figured it out yet?
  16. Kiwi SRT10
    1,012
    1,119
    Dec 16, 2019
    New Zealand
    How cool is that??
    Wow that's wicked
    Great job, well done
  17. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Hmmmm.
    I can't think of anything else but the radiator itself.
    AMS3 likes this.
  18. Kiwi SRT10
    1,012
    1,119
    Dec 16, 2019
    New Zealand
    Take the hoses off
    Jam the garden hose in there and turn it on, see if the water goes through the radiator.
    Then do the same with engine.
    Then with engine and radiator full take top hose off and start her up. WOOSH! yes you get wet.
    Great piece of mind tho
    Actually you could do the last step first
    AMS3 likes this.
  19. Tincup
    221
    106
    Feb 3, 2014
    MA.
    Thanks guy's I have been tied up on a house project that I promised the wife. I really thing the new (Stant) thermostat that I installed is not working properly. I bought a Motorad just in case and it seams to open more than the Stant ( I boiled both in the house ). Hopefully be back on it in another week or so...
  20. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    A happy wife is a happy home. Keep us updated on the coolant issue please.
    Tincup and Kiwi SRT10 like this.
