Interesting vid about rocker arm ratios and more power
Gooday.
The tab on the dipstick tube has to be cut off and relocated (brazed) as the valve cover bolt hole it used before is now 1" higher than it was due to the spacers.
Maybe that wasn't done (??)
Gooday.
The little things can cause big problems ..
Gooday.
I gave the bracket a tweak to fit as my spacers are 1/2". I am just not sure if the dipstick was pushed right home or not. I am keeping a watch on that. I may have to open the orifice up a smidge, if this keeps happening
The tube is fine, it was the dipstick that didn't put the dipstick in properly....maybe.
Make sure your catch can is routed properly and/or not overfull.
If the dipstick is trying to come out, you have excessive crankcase pressure for some reason that shouldn't be there.
